Changes between Version 5 and Version 6 of SOCIS/2016
- Timestamp:
- Jul 14, 2016, 4:31:08 PM (5 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
SOCIS/2016
v5 v6 46 46 * Jun 29: Off due to exams preparation. 47 47 * Jul 06: Prepared and tested Vagrant scripts to setup/build rtems and setup/build slingshot. Started changing test suite template to include a label that is moved to the next test case whenever a test case crashes. 48 * Jul 13: Added parsing output of test cases execution. Added support to tolerate crashes of test cases by proceeding to the next test case and re-making the test suite. This method is NOT scalable since it involves re-making the test suite. Going to execute test cases dynamically via RTEMS libdl to cope with this issue.
