Changes between Version 20 and Version 21 of SOCIS/2016
Ignore:
Timestamp:
Sep 14, 2016, 10:06:50 PM (3 years ago)
Author:
Saeed Ehteshamifar
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • SOCIS/2016
    v20 v21
    5555* Aug 31: Used 'ld -r' to combine test case object and test case setting file into one object file (Pavel Pisa's suggestion). Fixed the "symbol not found" issue while calling test cases by porting the test suite and test case template to C. Progressed in writing a sample DL app via WAF and updated the blog accordingly. Faced an "unresolved externals" error and posted the question to the ML. Going to continue with WAF for integration of the process to slingshot and also add a TCP link between the test suite and slingshot to pass the test case name to run it.
    5656* Sep 07: Tried to make a simple network app. Faced several issues. Going to debug them and report if they're RTEMS bugs.
    57 * Sep 14: Struggled more with writing a network app. Posted a question to the ML on how to use the new TCP/IP stack. Started merging changes back to Slingshot: porting the template to C, using OMK Makefile, using dynamic linking to run test cases. Will finish the merge and hopefully! networking by the next week.
     57* Sep 14: Struggled more with writing a network app. Posted a question to the ML on how to use the new TCP/IP stack. Started merging changes back to Slingshot: porting the template to C, using OMK Makefile, using dynamic linking to run test cases. Will finish merging and hopefully! networking by the next week.
