Changes between Version 15 and Version 16 of SOCIS/2016
Ignore:
Timestamp:
Aug 24, 2016, 3:02:51 PM (3 years ago)
Author:
Saeed Ehteshamifar
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • SOCIS/2016
    v15 v16
    5252* Aug 10: Ran Pavel Pisa's appdl (sample dynamically loaded app) with his help. Wrote a DL app, with OMK to make it (worked). Manually changed test case executor to see if everything works. Going to establish a TCP connection in test case executor between RTEMS and QEMU to pass test cases names. Then changing slingshot accordingly.
    5353* Aug 17: Wrapped up achievements about dynamic linking: updated the blog, the wiki, and the repository with a sample DL app. Tried to build the test suite via OMK, faced an error, posted a question to the mailing list. Tried to make a network app, both network-demos and my app didn't work. Going to fix these issues and finalize the test suite template (testcase executor).
    54 * Aug 22: Resolved the issue of compiling C++ files via OMK with Pavel Pisa's help (changing the extension to .cc). Manually changed the test suite template to dynamically load test cases. Fixed the configuration issue of the test suite (CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS). The new problem is to combine the test case's object file and the test setting's object file into one file to dynamically load it and call the test function.
     54* Aug 22: Resolved the issue of compiling C++ files via OMK with Pavel Pisa's help (changing the extension to .cc). Manually changed the test suite template to dynamically load test cases. Fixed a configuration issue of the test suite (CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS). The new problem is to combine the test case's object file and the test setting's object file into one file to dynamically load it and call the test function.
