Changes between Version 10 and Version 11 of SOCIS/2016
Ignore:
Timestamp:
Aug 11, 2016, 11:57:05 AM (3 years ago)
Author:
Saeed Ehteshamifar
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • SOCIS/2016
    v10 v11
    5050* Jul 27: Updated build instructions to re-produce the work via Vagrant. Tried to use libdl01 example in test suites to make a dynamically linked (DL) application (not fruitful). Going to follow community's instructions to build it.
    5151* Aug 03: Tried Chris John's instructions to build a DL app via WAF build system (didn't work). Tried Pavel Pisa's instructions to build it via OMK build system (worked). Going to change the test executor to TAR all test cases and dynamically load and execute them at run-time.
     52* Aug 10: Ran Pavel Pisa's appdl (sample dynamically loaded app) with his help. Wrote a DL app, with OMK to make it (worked). Manually changed test case executor to see if everything works. Going to establish a TCP connection in test case executor between RTEMS and QEMU to pass test cases names. Then changing slingshot accordingly.
