Changes between Version 38 and Version 39 of SOCIS/2015
- Timestamp:
- Oct 20, 2015, 9:31:45 AM (5 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
SOCIS/2015
v38 v39 13 13 ||NAME || Yes or No || nick on #rtems || Project Title || Link to Google Docs for proposal (shared with mentors) 14 14 ||Hermann Felbinger || Yes || hermann_19829 || Improve Code Coverage Analysis Meeting Aviation and Automotive Standards || [https://docs.google.com/document/d/14akfj6AIc0HBZ1ZSTc8Hp7MX8k7wrh495Jl3ngvTJDQ/edit?usp=sharing Proposal] 15 || Saeed Ehteshamifar || Yes || salpha || RTEMS Fault tolerance: Get a fault injection tool to work with RTEMS || [https://docs.google.com/document/d/1rVEhyHXajAVMcqgrOR-0t84596QUkYOnifoaYpa8QYM/pub?usp=sharing Proposal] 15 || Saeed Ehteshamifar || Yes || salpha || RTEMS Fault tolerance: Get a fault injection tool to work with RTEMS || [https://docs.google.com/document/d/1rVEhyHXajAVMcqgrOR-0t84596QUkYOnifoaYpa8QYM/pub?usp=sharing Proposal] [https://docs.google.com/document/d/1DVbwDUEf0DDzzLQbYQo7oPF0zKwueCaLS87cqKSlsGw/pub Final Report] 16 16 17 17 … … 75 75 * Aug 18: Modified Slingshot to generate RTEMS programs. Statically running each test case by calling the corresponding test function. Should improve generated source files. 76 76 * Aug 25: Improved code generation by using C macros and C Pre-Processor to avoid source code redundancy. Added to Slingshot a call to Linux Make to build test program. Should wrap up and prepare to publish Slingshot repository. 77 * Sep 01: Wrapped up Slingshot and published it on GitHub. Wrote final report (which contains future works) and put the link to it on this page.
