- Timestamp:
08/26/15 12:20:56 (9 years ago)
- Author:
Saeed Ehteshamifar
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v36
v37
73 | 73 | * Aug 04: Gone through Slingshot's source code. Tried to initialize and run Slingshot on a virtual Linux instance. Fixed some issues in the process of running it. Should omit execution of test suites and port test case template to RTEMS. |
74 | 74 | * Aug 11: Omitted execution phase of Slingshot and manually ported its test case template to RTEMS. Should adapt to RTEMS' process model with respect to how to invoke module under test's process and monitor it (catch signals). |
| 75 | * Aug 18: Modified Slingshot to generate RTEMS programs. Statically running each test case by calling the corresponding test function. Should improve generated source files. |
| 76 | * Aug 25: Improved code generation by using C macros and C Pre-Processor to avoid source code redundancy. Added to Slingshot a call to Linux Make to build test program. Should wrap up and prepare to publish Slingshot repository. |
