Changes between Version 2 and Version 3 of SOCIS/2015/CoverageAnalysis
- Timestamp:
- 07/10/15 13:01:49 (9 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v2 v3 9 9 '''Students:''' Hermann Felbinger 10 10 11 '''Status:''' Uninitiated.11 '''Status:''' Running. 12 12 13 '''Introduction:''' The goal of this project is to improve the reporting of structural coverage analysis on testing RTEMS. The existing coverage analysis implementation supports statement and branch coverage. Mainly the tool for generating reports of this coverage analysis implementation is updated. The detailed coverage analyisis reports are generated providing hints to uncovered code fragments depending on the used coverage metrics. Further the coverage analysis tool is extended to evaluate also MC/DC (Modified Condition/Decision Coverage). 13 '''Introduction:''' The goal of this project is to improve the reporting of structural coverage analysis on testing RTEMS. The existing coverage analysis implementation supports statement and branch coverage. Mainly the tool for generating reports of this coverage analysis implementation is updated. The detailed coverage analyisis reports are generated providing hints to uncovered code fragments depending on the used coverage metrics. Further the coverage analysis tool is extended to evaluate also MC/DC (Modified Condition/Decision Coverage). 14 14 15 ''' Goal:''' Concise statement of the overall goal of the project. Refine this initial statement to include: project deliverables (code, docs, testing), required/suggested methodology, standards of quality, possible goal extensions beyond the main objective.15 '''Resources:''' A howto and the required resources for this project can be found in https://socis2015rtems.blogspot.com/ 16 16 17 '''Requirements:''' List the requirements and level of expertise you estimate are required by the developer tackling this project will have to have: Required level of programming language(s), specific areas of RTEMS or tools, level of familiarity with RTEMS, cross-development, GNU/Linux, etx., development/documentation/testing tools, mathematical/algorithmic background, other desirable skills.18 19 '''Resources:''' Current RTEMS developers, papers, etc that may help you in this project.20 21 '''Acknowledgements'''22 * who helped and did work23 24 = Miscellaneous Sections =25 26 As the project progresses, you will need to add build instructions, etc and this page will evolve from a project description into a HOWTO.27 28 = References =29 * TBD30 31 '''Other sections:''' If you have more to say about the project that doesn't fit in the proposed sections of this template, feel free to add other sections at will.
