Changes between Version 30 and Version 31 of Release/4.9
Ignore:
Timestamp:
Apr 23, 2008, 12:43:42 AM (14 years ago)
Author:
JoelSherrill
Comment:
/* API Implementation Improvements */ Add removal of name tale
Legend:
Unmodified
Added
Removed
Modified
  • Release/4.9
    v30 v31
    8181  *  More files with multiple methods were split including the Malloc Family, POSIX timers, and many of the POSIX stubs for routines RTEMS does not support.
    8282  *  When a set of initialization tasks or threads is not configured for a particular API, those task/thread creation routines are no longer required in the minimum executable.  For examnple, in 4.8 and older, the code to create POSIX initialization threads was always present when POSIX was enabled and thus pthread_create() was included in the executable.
     83
     84 *  Each object class no longer allocates a name table.  The name information is always stored directly with the object.  This was an improvement in memory usage.
    8385= Configuration Changes =
    8486
