Changes between Version 16 and Version 17 of Release/4.9
- Timestamp:
- 02/06/08 19:57:43 (16 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Release/4.9
v16 v17 114 114 115 115 116 * As part of adding the new set of Object Services, some existing 117 undocumented routines that previously existed were renamed as follows: 116 This section covers the API changes between the 4.8 and 4.9 release series which are expected to have an impact on application source code. This section does NOT cover additions to the API. 117 118 * As part of adding the new set of Object Services, some existing undocumented routines that previously existed were renamed as follows: 118 119 * Renamed rtems_get_node() to rtems_object_id_get_node() 119 120 * Renamed rtems_get_api() to rtems_object_id_get_api()
