Changes between Version 164 and Version 165 of Release/4.9
Ignore:
Timestamp:
Mar 10, 2010, 9:14:03 PM (10 years ago)
Author:
JoelSherrill
Comment:
/* Release 4.9.2 Changes */
Legend:
Unmodified
Added
Removed
Modified
  • Release/4.9
    v164 v165
    279279
    280280Issues With Problems Report Numbers
    281  *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1349 1349/bsps - PowerPC Haleakala BSP UART initialisation is faulty.  Missing volatiles.
    282  *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1350 1350/bsps - arm/csb336/network/lan91c11x.c: array subscript is above array bounds
    283  *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1351 1351/cpukit - confdefs.h does not clear unlimited bit in memory calculations
    284  *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1352 1352/bsps - include support for mvme2600 and mvme2700 in motorola_shared BSP
     281 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1349 1349/bsps] - PowerPC Haleakala BSP UART initialisation is faulty.  Missing volatiles.
     282 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1350 1350/bsps] - arm/csb336/network/lan91c11x.c: array subscript is above array bounds
     283 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1351 1351/cpukit] - confdefs.h does not clear unlimited bit in memory calculations
     284 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1352 1352/bsps] - include support for mvme2600 and mvme2700 in motorola_shared BSP
    285285 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1354 1354/bsps] - AV5282 Network driver can put empty mbuf on descriptor chain
    286286 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1355 1355/filesystem] - SD card code rejects MMC and random blocks written sequentially
