251 | | * 1395/bsps - MVME5500 BSP Bug fixes and performance upgrade |
252 | | * 1378/filesystem - seek device file system handler returns 0 not offset |
253 | | * 1409/bsps - GDB Stub Shared Code Does Not Print Object Names Correctly |
254 | | * 1411/cpukit - rtems_workspace_XXX routines enhanced (NOTE: these were new in 4.9 and unlikely to be used.) |
255 | | * 1412/cpukit - Missing brackets in coremutex.c |
256 | | * 1413/cpukit - anomalous behavior of timer server scheduling when rescheduling timers from the TSR |
257 | | * 1415/cpukit - Semaphore obtain with invalid priority ceiling |
258 | | * 1420/bsps - m68k/uC5282: turn off buffered writes. MCF5282 chip errata -- Buffered Write May Be Executed Twice |
259 | | * 1438/bsps - inline assembly for STOP instruction clobbers CCR |
260 | | * 1451/bsps - bsdnet watchdog on mvme3100 leaks mbufs |
261 | | * 1462/cpukit - fix bug in rate monotonic statistics |
262 | | * 1468/cpukit - Math overflow in timespecdividebyinteger.c |
263 | | * 1469/cpukit - Wrong exception handler prologues for exceptions >= 16 (i386) |
264 | | * 1471/cpukit - CPU Usage report Math overflow with ticks statistics |
| 251 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1395 1395/bsps] - MVME5500 BSP Bug fixes and performance upgrade |
| 252 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1378 1378/filesystem] - seek device file system handler returns 0 not offset |
| 253 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1409 1409/bsps] - GDB Stub Shared Code Does Not Print Object Names Correctly |
| 254 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1411 1411/cpukit] - rtems_workspace_XXX routines enhanced (NOTE: these were new in 4.9 and unlikely to be used.) |
| 255 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1412 1412/cpukit] - Missing brackets in coremutex.c |
| 256 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1413 1413/cpukit] - anomalous behavior of timer server scheduling when rescheduling timers from the TSR |
| 257 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1415 1415/cpukit] - Semaphore obtain with invalid priority ceiling |
| 258 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1420 1420/bsps] - m68k/uC5282: turn off buffered writes. MCF5282 chip errata -- Buffered Write May Be Executed Twice |
| 259 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1438 1438/bsps] - inline assembly for STOP instruction clobbers CCR |
| 260 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1451 1451/bsps] - bsdnet watchdog on mvme3100 leaks mbufs |
| 261 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1462 1462/cpukit] - fix bug in rate monotonic statistics |
| 262 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1468 1468/cpukit] - Math overflow in timespecdividebyinteger.c |
| 263 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1469 1469/cpukit] - Wrong exception handler prologues for exceptions >= 16 (i386) |
| 264 | * [https://www.rtems.org/bugzilla/show_bug.cgi?id=1471 1471/cpukit] - CPU Usage report Math overflow with ticks statistics |
