Changes between Version 87 and Version 88 of Release/4.8
Ignore:
Timestamp:
Mar 18, 2010, 10:09:02 PM (10 years ago)
Author:
JoelSherrill
Comment:
/* Release 4.8.2 Changes */ Convert PRs to Bugzilla links
Legend:
Unmodified
Added
Removed
Modified
  • Release/4.8
    v87 v88
    162162
    163163Issues With Problems Report Numbers
    164  *  1297/cpukit - pthread_rwlock_init misinterprets NULL attr pointer
    165  *  1313/cpukit - "rtems_pty_maximum_ptys" not initialized
    166  *  1316/cpukit - message queue broadcast truncated messages that were too long and should have return an error per the documentation
    167  *  1330/cpukit - free.c: Print of wrong address in error message
    168  *  1333/cpukit - typo in termiostypes.h uses major instead of minor
    169  *  1334/doc - Misc Documentation Typos and Object ID correction
    170  *  1337/bsps - Stripping .rodata section produces unusable executables for the i386-rtems target.
    171  *  1348/cpukit - Resetting CPU usage information while a period is running results in a negative minimum cpu time used being reported.
    172  *  1350/bsps - arm/csb336/network/lan91c11x.c: array subscript is above array bounds
    173  *  1354/bsps - AV5282 Network driver can put empty mbuf on descriptor chain
    174  *  1357/cpukit - creating task with RTEMS_NO_ASR has no effect
    175  *  1359/cpukit - rtems_libio_allocate: rtems_libio_iop_freelist incorrectly zeroed on semaphore error
    176  *  1363/filesystem - Fix issue where 32 bit values are not written correctly in FAT f/s data.
    177  *  1364/cpukit - gxx_wrappers.c won't compile with diagnostics enabled
    178  *  1376/filesystem - lseek filesystem internal handlers should return off_t
    179  *  1378/filesystem - seek device file system handler returns 0 not offset
    180  *  1380/bsps - Unreadable comments in c/src/lib/libbsp/arm/rtl22xx/include/bsp.h
    181  *  1387/doc - Add Interrupt Manager services to set callable from ISR
    182  *  1388/cpukit - Classic Semaphores allow both priority inherit and ceiling attributes to be set
    183  *  1391/bsps - sparc BSPs spurious handler printk format error
    184  *  1396/bsps - mvme5500 update from Kate Feng
    185  *  1414/cpukit - Valid Id of Wrong Object Type Accepted
    186  *  1415/cpukit - Semaphore obtain with invalid priority ceiling
    187  *  1421/filesystem - Backport ftruncate support for devices so fopen(device, "w") works
    188  *  1482/cpukit - POSIX timer_settime has path which does not exit dispatching critical section
     164 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1297 1297/cpukit] - pthread_rwlock_init misinterprets NULL attr pointer
     165 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1313 1313/cpukit] - "rtems_pty_maximum_ptys" not initialized
     166 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1316 1316/cpukit] - message queue broadcast truncated messages that were too long and should have return an error per the documentation
     167 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1330 1330/cpukit] - free.c: Print of wrong address in error message
     168 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1333 1333/cpukit] - typo in termiostypes.h uses major instead of minor
     169 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1334 1334/doc] - Misc Documentation Typos and Object ID correction
     170 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1337 1337/bsps] - Stripping .rodata section produces unusable executables for the i386-rtems target.
     171 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1348 1348/cpukit] - Resetting CPU usage information while a period is running results in a negative minimum cpu time used being reported.
     172 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1350 1350/bsps] - arm/csb336/network/lan91c11x.c: array subscript is above array bounds
     173 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1354 1354/bsps] - AV5282 Network driver can put empty mbuf on descriptor chain
     174 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1357 1357/cpukit] - creating task with RTEMS_NO_ASR has no effect
     175 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1359 1359/cpukit] - rtems_libio_allocate: rtems_libio_iop_freelist incorrectly zeroed on semaphore error
     176 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1363 1363/filesystem] - Fix issue where 32 bit values are not written correctly in FAT f/s data.
     177 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1364 1364/cpukit] - gxx_wrappers.c won't compile with diagnostics enabled
     178 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1376 1376/filesystem] - lseek filesystem internal handlers should return off_t
     179 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1378 1378/filesystem] - seek device file system handler returns 0 not offset
     180 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1380 1380/bsps] - Unreadable comments in c/src/lib/libbsp/arm/rtl22xx/include/bsp.h
     181 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1387 1387/doc] - Add Interrupt Manager services to set callable from ISR
     182 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1388 1388/cpukit] - Classic Semaphores allow both priority inherit and ceiling attributes to be set
     183 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1391 1391/bsps] - sparc BSPs spurious handler printk format error
     184 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1396 1396/bsps] - mvme5500 update from Kate Feng
     185 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1414 1414/cpukit] - Valid Id of Wrong Object Type Accepted
     186 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1415 1415/cpukit] - Semaphore obtain with invalid priority ceiling
     187 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1421 1421/filesystem] - Backport ftruncate support for devices so fopen(device, "w") works
     188 *  [https://www.rtems.org/bugzilla/show_bug.cgi?id=1482 1482/cpukit] - POSIX timer_settime has path which does not exit dispatching critical section
    189189
    190190Issues Without Problems Report Numbers
