- Timestamp:
08/13/08 19:22:54 (16 years ago)
- Author:
JoelSherrill
- Comment:
/* Release 4.8.1 Changes */ Add PR1257, use rtems interrupt disable/enable instead of CPU routines
Legend:
- Unmodified
- Added
- Removed
- Modified
v50
v51
151 | 151 | * PR1212 - Correctly enabled timeslicing when done by calling task. Adds sp44. |
152 | 152 | * PR1237 - SPARC port specific modifications to avoid overflowing interrupted task stack under high load |
| 153 | * PR1257 - Various BSPs: Use rtems_interrupt_disable and enable instead of directly using _CPU_ISR_Enable and _CPU_ISR_Disable. Ensures proper compiler memory barrier usage. |
153 | 154 | * PR1263 - User's Guide Partition: Improve discussion of alignment and minimum buffer sizes. |
154 | 155 | * PR1265 - objectbyindex.c and prototype - rename parameter so including rtems.h and string.h in user code does not give warning. |
