Changes between Version 6 and Version 7 of Release/4.7
- Timestamp:
- 06/15/07 20:11:02 (17 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Release/4.7
v6 v7 106 106 * Stack Checker now bounds checks the actual stack pointer in addition to checking the end of stack memory. A user application had a 4K unused buffer on a task stack and the stack checked missed this. 107 107 * PR1234 comments: Provided RTEMS specific implementation of __assert which uses printk. This reduced executable size by 12K on applications not requiring printf() support. It also ensured that one should be able to assert from RTEMS critical sections and interrupts. 108 * Stack Checker converted to use printk so there is a higher probability of getting a failure message. Added dummy printk support to multiple BSPs so all tests will link. 108 * Stack Checker converted to use printk so there is a higher probability of getting a failure message. 109 * Added dummy printk support to multiple BSPs so all tests will link. 109 110 * ITRON rsm_tsk error code 110 111 * MIPS Little and .sdata (aka R_MIPS_GPREL16 problem)
