Changes between Version 13 and Version 14 of Release/4.6
Ignore:
Timestamp:
02/21/08 00:54:39 (15 years ago)
Author:
JoelSherrill
Comment:
Add message about 4.6 being in legacy support mode.
Legend:
Unmodified
Added
Removed
Modified
  • Release/4.6
    v13 v14
    22
    33
    4 Release [wiki:4.6_Release_Notes#Release_4.6.6_Changes  4.6.6] is the latest version in the 4.6 release series. Release 4.6.6 of RTEMS is primarily a problem fixing release and the problems addressed are discussed here. The primary driving factor for [wiki:4.6_Release_Notes#Release_4.6.6_Changes  4.6.6] was a patch to address GCC optimizing code outside of interrupt disable critical sections. Other bug fixes and improvements were also committed to the branch so this release includes them. The notable changes are that the SPARC LEON3 BSP received significant improvements including supprt for SpaceWire and a new NIC from Gaisler Research. The PC386 BSP was modified to allow easy compile time selection of VGA or COM1 as the console.
     4Release [wiki:4.6_Release_Notes#Release_4.6.6_Changes  4.6.6] is the '''LAST PUBLIC RELEASE''' in the 4.6 release series from the RTEMS Project.
     5Legacy support for the 4.6 releases is available from [http://www.rtems.org/oarsupport/ OAR Corporation].
     6
     7Release 4.6.6 of RTEMS is primarily a problem fixing release and the problems addressed are discussed here. The primary driving factor for [wiki:4.6_Release_Notes#Release_4.6.6_Changes  4.6.6] was a patch to address GCC optimizing code outside of interrupt disable critical sections. Other bug fixes and improvements were also committed to the branch so this release includes them. The notable changes are that the SPARC LEON3 BSP received significant improvements including supprt for SpaceWire and a new NIC from Gaisler Research. The PC386 BSP was modified to allow easy compile time selection of VGA or COM1 as the console.
    58
    694.6.6 is available for download from ftp://ftp.rtems.com/pub/rtems/4.6.6 or . http://www.rtems.com/ftp/pub/rtems/4.6.6.
