- Timestamp:
11/15/16 16:14:46 (8 years ago)
- Author:
Gedare Bloom
- Comment:
Remove some TBDs
Legend:
- Unmodified
- Added
- Removed
- Modified
v24
v25
61 | 61 | * Please note that the chroot() function uses a private environment. If chroot() an appropriate number of key-value pair is necessary. |
62 | 62 | * Please note that the ftp-server uses chroot() and therefore needs an appropriate number of key-value pairs. |
63 | | * TBD |
64 | 63 | |
65 | 64 | === API Additions |
82 | 81 | * There is a new fatal error function rtems_fatal(). |
83 | 82 | * New Classic Semaphore directive: [https://docs.rtems.org/doc-current/share/rtems/html/c_user/Semaphore-Manager-SEMAPHORE_005fSET_005fPRIORITY-_002d-Set-priority-by-scheduler-for-a-semaphore.html#Semaphore-Manager-SEMAPHORE_005fSET_005fPRIORITY-_002d-Set-priority-by-scheduler-for-a-semaphore rtems_semaphore_set_priority()]. |
84 | | * TBD |
85 | 83 | |
86 | 84 | === API Implementation Improvements |
92 | 90 | * the read-only data is valid, and |
93 | 91 | * the read-write data is accessible. |
94 | | * TBD |
95 | 92 | |
96 | 93 | === API Deprecations |
111 | 108 | * The Configuration is now read-only and must be statically initialized via confdefs.h or similar. |
112 | 109 | * BSPs can now register an initial extension via the BSP_INITIAL_EXTENSION define. |
113 | | * TBD |
| 110 | |
114 | 111 | |
115 | 112 | === RTEMS Shell Improvements |
119 | 116 | |
120 | 117 | * New command ''lsof'' to list all referenced file system locations. |
121 | | * TBD |
| 118 | |
122 | 119 | |
123 | 120 | === General |
133 | 130 | * The '''exit()''', '''_exit()''' and '''abort()''' functions lead to a fatal error. The fatal source is '''RTEMS_FATAL_SOURCE_EXIT''' and the fatal code is the exit status. The '''rtems_panic()''' and '''rtems_error()''' are also affected by this since they call one of these functions. Depending on the fatal error extensions this may lead to a '''bsp_reset()'''. A reset is the default provided by the BSP. |
134 | 131 | * [http://rtems.org/onlinedocs/doc-current/share/rtems/html/cpu_supplement/Port-Specific-Information-Thread_002dLocal-Storage.html#Port-Specific-Information-Thread_002dLocal-Storage Thread-local storage (TLS)]: Supported on ARM, m68k, PowerPC and SPARC. Other architectures lack an implementation. |
135 | | * TBD |
| 132 | |
136 | 133 | |
137 | 134 | * Scheduler Refactoring Improvements |
