Changes between Version 7 and Version 8 of Release/4.10
Ignore:
Timestamp:
Sep 22, 2008, 2:51:45 PM (11 years ago)
Author:
YanMiao
Comment:
/* Configuration Changes */
Legend:
Unmodified
Added
Removed
Modified
  • Release/4.10
    v7 v8
    5656 *  STACK_CHECKER_ON renamed to CONFIGURE_STACK_CHECKER_ENABLED.
    5757
    58  *  Filesystem support can be controlled by the user. By default, filesystem infrastructure
    59 is included, define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM to disable filesystem support.
     58 *  Filesystem support can be controlled by the user. By default, filesystem infrastructure is included, define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM to disable filesystem support.
    6059
    6160 *  RTEMS now has a device-only filesystem which is smaller in size than miniIMFS and IMFS, define CONFIGURE_USE_DEVFS_AS_BASE_FILESYTEM to enable this configuration.
