Changes between Version 42 and Version 43 of Release/4.10
- Timestamp:
- 10/21/09 16:52:11 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Release/4.10
v42 v43 99 99 * SuperCore Timestamp Handler added. This includes the capability to select struct timespec or int64_t as the data type used for internal RTEMS time management. 100 100 101 * Heap and region now use intptr_t for size of memory pools and individual allocations. size_t is only defined to have a range large enough to represent the size of a SINGLE allocated object so this is necessary for correctness and to fix breakages on 16-bit targets.101 * Heap and region now use uintptr_t for size of memory pools and individual allocations. size_t is only defined to have a range large enough to represent the size of a SINGLE allocated object so this is necessary for correctness and to fix breakages on 16-bit targets. 102 102 103 103 * RTEMS now supports configuring less than 256 priorities. During the 4.10 development cycle, all tests were run in a configuration that had a maximum of 16 priorities. This involved improvements to the tests to react to the number of priority levels not being a static value and fixed some bugs in the POSIX and ITRON API implementations.
