- Timestamp:
07/24/09 10:12:06 (15 years ago)
- Author:
ChrisJohns
- Comment:
ITRON disabled changed
Legend:
- Unmodified
- Added
- Removed
- Modified
v37
v38
79 | 79 | |
80 | 80 | * Provide a C linkage Init task prototype. By default the Init task now expects a pointer to a global command line string. Set this pointer to NULL is no command line is present. A shared BSP Init task is also provided with weak external linkage so you can now write an application that enters with main rather Init. |
| 81 | |
| 82 | * ITRON configuration defaults to "no". One now has to explicitly pass <i>--enable-itron</i> to configure to build it. |
81 | 83 | |
82 | 84 | * TBD |
