Changes between Version 15 and Version 16 of Release/4.10
Ignore:
Timestamp:
Dec 16, 2008, 1:19:22 AM (11 years ago)
Author:
JoelSherrill
Comment:
/* General */ Add testing in 16 priority configuration
Legend:
Unmodified
Added
Removed
Modified
  • Release/4.10
    v15 v16
    8686
    8787 *  Heap and region now use intptr_t for size of memory pools and individual allocations.  size_t is only defined to have a range large enough to represent the size of a SINGLE allocated object so this is necessary for correctness and to fix breakages on 16-bit targets.
     88
     89 *  RTEMS now supports configuring less than 256 priorities.  During the 4.10 development cycle, all tests were run in a configuration that had a maximum of 16 priorities.  This involved improvements to the tests to react to the number of priority levels not being a static value and fixed some bugs in the POSIX and ITRON API implementations.
    8890= BSPs and Device Drivers =
    8991
