Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
Changes between Version 4 and Version 5 of References/1999
Ignore:
Timestamp:
01/17/16 16:02:57 (8 years ago)
Author:
Isaac
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • References/1999
    v4 v5
    33[[TOC(References/1999 , depth=2)]]
    44
    5 * A. Colin, I. Puaut. "Worst-Case Execution Time Analysis of the RTEMS Real-Time Operating System.", Published in the 13th Euromicro Conference on Real-Time Systems. IRISA technical report NoPI1236, November 1999. //This paper appears to be based on the same work that was later published at !EuroMicro?. This work is from the [http://www.irisa.fr/solidor/work/hades.html ​Hades -- Operating Systems for critical applications] site. They have at least this one paper on RTEMS. Sadly, this paper is mostly correct but unfortunately the authors misunderstood at least one RTEMS algorithm and incorrectly cited it as non-deterministic. :(//
     5* A. Colin, I. Puaut. "Worst-Case Execution Time Analysis of the RTEMS Real-Time Operating System.", Published in the 13th Euromicro Conference on Real-Time Systems, IRISA technical report NoPI1236, November 1999. //This paper appears to be based on the same work that was later published at !EuroMicro?. This work is from the [http://www.irisa.fr/solidor/work/hades.html ​Hades -- Operating Systems for critical applications] site. They have at least this one paper on RTEMS. Sadly, this paper is mostly correct but unfortunately the authors misunderstood at least one RTEMS algorithm and incorrectly cited it as non-deterministic. :(//
    66
    77* ​M. I. Panasyuk, A. G. Myasnikov, A.I. Akulin, E. O. Asoskova, A. A. Beliaev, & D. V. Kalinin. "Current status of the Radiation Monitoring System for ISS/RS and preliminary results for its component testing onboard MIR station", [http://www.wrmiss.org/workshops/fourth/ Fourth Workshop on Radiation Monitoring for the International Space Station], Farnborough, Hampshite, UK, 1999. [http://wrmiss.org/workshops/fourth/akulin.pdf]
