- Timestamp:
01/17/16 15:59:42 (8 years ago)
- Author:
Isaac
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v1
v2
3 | 3 | [[TOC(References/1999 , depth=2)]] |
4 | 4 | |
5 | | * [http://www.magnet.oma.be/wrmiss/workshops/fourth/akulin.pdf Current status of the Radiation Monitoring System for ISS/RS and preliminary results for its component testing onboard MIR station]. M.I. Panasyuk, A.G. Myasnikov, A.I.Akulin, E.O.Asoskova, A.A.Beliaev, and D.V. Kalinin. [http://www.magnet.oma.be/wrmiss/wrmiss.html Fourth Workshop on Radiation Monitoring for the International Space Station]. Farnborough, Hamps-h-i-t-e (ignore dashes, without them spam filter is tripped), UK. WRMISS-99. |
| 5 | * A. Colin, I. Puaut. "Worst-Case Execution Time Analysis of the RTEMS Real-Time Operating System.", Published in the 13th Euromicro Conference on Real-Time Systems. IRISA technical report NoPI1236, November 1999. //This paper appears to be based on the same work that was later published at !EuroMicro?. This work is from the [http://www.irisa.fr/solidor/work/hades.html Hades -- Operating Systems for critical applications] site. They have at least this one paper on RTEMS. Sadly, this paper is mostly correct but unfortunately the authors misunderstood at least one RTEMS algorithm and incorrectly cited it as non-deterministic. :(// |
6 | 6 | |
7 | | * To Ada or not To Ada: Adaing vs. Javaing in Real-Time Systems. Luís Miguel Pinho and Francisco Vasques. ACM Ada Letters, Vol. XIX, N. 4, pp 37-43, December 1999. |
| 7 | * M. I. Panasyuk, A. G. Myasnikov, A.I. Akulin, E. O. Asoskova, A. A. Beliaev, & D.V. Kalinin. "Current status of the Radiation Monitoring System for ISS/RS and preliminary results for its component testing onboard MIR station", [http://www.wrmiss.org/workshops/fourth/ Fourth Workshop on Radiation Monitoring for the International Space Station]. Farnborough, Hampshite, UK, 1999. [http://wrmiss.org/workshops/fourth/akulin.pdf] |
8 | 8 | |
9 | | * "Worst-Case Execution Time Analysis of the RTEMS Real-Time Operating System." A. Colin, I. Puaut. Proc. of the 13th Euromicro Conference on Real-Time Systems. IRISA technical report NoPI1236, November 1999. This paper appears to be based on the same work that was later published at EuroMicro?. This work is from the [http://www.irisa.fr/solidor/work/hades.html Hades -- Operating Systems for critical applications] site. They have at least this one paper on RTEMS. Sadly, this paper is mostly correct but unfortunately the authors misunderstood at least one RTEMS algorithm and incorrectly cited it as non-deterministic. :( |
10 | | |
11 | | * [http://citeseer.nj.nec.com/336076.html Replica Management in Real-Time Ada 95 Application]. Luís Miguel Pinho and Francisco Vasques. Submitted to IRTAW-99. |
| 9 | * L. M. Pinho & F. Vasques. "To Ada or not To Ada: Adaing vs. Javaing in Real-Time Systems", ACM Ada Letters, Vol. XIX, N. 4, pp 37-43, December 1999. [http://paginas.fe.up.pt/~vasques/research/publi_98/adaletters98b.pdf] |
| 10 | |
| 11 | * L. M. Pinho & F. Vasques. "Replica Management in Real-Time Ada 95 Application", Submitted to IRTAW-99. [http://citeseer.nj.nec.com/336076.html] |
