Changes between Version 13 and Version 14 of RTEMSMailingLists
Ignore:
Timestamp:
Jun 19, 2010, 6:30:54 PM (10 years ago)
Author:
JoelSherrill
Comment:
No direct search page at this point for lists which we do not run mhonarc on.
Legend:
Unmodified
Added
Removed
Modified
  • RTEMSMailingLists
    v13 v14
    2020  *  Subscription Page: http://www.rtems.org/mailman/listinfo/rtems-announce
    2121
    22  *  [http://www.rtems.com/ml/rtems-bugs RTEMS Bugs] has all bug database changes posted. Discussion about a bug can occur on the list but it is preferred a discussion take place in bugzilla where it can be captured and recorded.
    23   *  Search page: http://www.rtems.org/ml/rtems-bugs/index.html
    2423  *  Pipermail archive: http://www.rtems.org/pipermail/rtems-bugs
    2524  *  Subscription Page: http://www.rtems.org/mailman/listinfo/rtems-bugs
    2625
    2726 *  [http://www.rtems.com/ml/rtems-smp RTEMS SMP] is the primary place where discussion about SMP changes to RTEMS occurs.
    28   *  Search page: http://www.rtems.org/ml/rtems-smp/index.html
    2927  *  Pipermail archive: http://www.rtems.org/pipermail/rtems-smp
    3028  *  Subscription Page: http://www.rtems.org/mailman/listinfo/rtems-smp
    3129
    3230 *  [http://www.rtems.com/ml/rtems-vc RTEMS Version Control] has all changes to the RTEMS Version Control system posted. Discussion about changes can take place on this list.
    33   *  Search page: http://www.rtems.org/ml/rtems-vc/index.html
    3431  *  Pipermail archive: http://www.rtems.org/pipermail/rtems-vc
    3532  *  Subscription Page: http://www.rtems.org/mailman/listinfo/rtems-vc
    3633
    37  *  [http://www.rtems.com/ml/rtems-tooltestresults RTEMS Tool Test Results] is a list where test results for the GCC compilers targeting RTEMS are posted.  Automated tool test runs conducted by OAR personnel will be reported to this list as well as to the [http://gcc.gnu.org/ml/gcc-testresults] mailing list.  If you run the GCC test suite yourself on an RTEMS target, feel free to post to this mailing list.  At some point in the future, we hope to add binutils and gdb test results.
     34 *  [http://www.rtems.org/pipermail/rtems-tooltestresults/ RTEMS Tool Test Results] is a list where test results for the GCC compilers targeting RTEMS are posted.  Automated tool test runs conducted by OAR personnel will be reported to this list as well as to the [http://gcc.gnu.org/ml/gcc-testresults] mailing list.  If you run the GCC test suite yourself on an RTEMS target, feel free to post to this mailing list.  At some point in the future, we hope to add binutils and gdb test results.
    3835  *  Pipermail archive: http://www.rtems.org/pipermail/rtems-tooltestresults
    3936  *  Subscription Page: http://www.rtems.org/mailman/listinfo/rtems-tooltestresults
