32 | | # A program that will run the LDAP testing suite provided by OpenLDAP. ''Should be automated, as additional tests will be used in the future.''== = RTEMS Source Tree Port (6 months to 2 years away) === |
33 | | |
34 | | # The method used to transform the OpenLDAP Makefiles and RTEMS Addon Packages oriented Makefiles to RTEMS source Makefile.am's |
35 | | # A patch making the the needed configurations defaults in the OpenLDAP's configure.in and Makefile.am. |
36 | | # In an ideal world this would be based upon other libraries installed on RTEMS, for example: SSL HAS to be optional, as encryption is illegal in some countries. |
37 | | == Suggested Methodology == |
| 32 | # A program that will run the LDAP testing suite provided by OpenLDAP. ''Should be automated, as additional tests will be used in the future.''== Suggested Methodology == |
