Changes between Version 30 and Version 31 of Projects/OpenLDAP
- Timestamp:
- 06/22/12 07:22:14 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Projects/OpenLDAP
v30 v31 26 26 27 27 Just some ideas from C Rempel: 28 == = A port designed to work with an RTEMS Addon Packages variant called the RTEMS Webkit.===28 == = RTEMS Webkit Port === 29 29 30 30 # A Makefile.openldap that builds the SlapD libraries for RTEMS applications 31 31 # A Makefile that builds the programs. 32 # A program that will run the LDAP testing suite provided by OpenLDAP. ''Should be automated, as additional tests will be used in the future.''== = A port designed to work within the RTEMS source tree===32 # A program that will run the LDAP testing suite provided by OpenLDAP. ''Should be automated, as additional tests will be used in the future.''== = RTEMS Source Tree Port (6 month to 2 years away) === 33 33 34 34 # The method used to transform the OpenLDAP Makefiles and RTEMS Addon Packages oriented Makefiles to RTEMS source Makefile.am's
