Changes between Version 16 and Version 17 of Projects/OpenLDAP
- Timestamp:
- 06/21/12 22:55:25 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Projects/OpenLDAP
v16 v17 159 159 select text composed of letters and format it ... 160 160 add a line a right brace, and another line after any .exe ... 161 = examples/openldap/Makefile=161 == examples/openldap/Makefile == 162 162 163 163 … … 249 249 install: all 250 250 $(INSTALL_VARIANT) -m 555 ${PGMS} /usr/local/tftpboot/bootfiles/m68360/ 251 = leaf.cfg=252 253 To build the executables , I had to change some lines in /opt/rtems-4.11/make/leaf.cfg. nm and size work on object files, with the below changes the build process not only gives fewer errors, but generates .bin and .ralf files in examples/openldap/o-optimize!251 == leaf.cfg == 252 253 To build the executables without errors, I had to change some lines in /opt/rtems-4.11/make/leaf.cfg. nm and size work on object files, with the below changes the build process not only gives fewer errors, but generates .bin and .ralf files in examples/openldap/o-optimize! 254 254 255 255 define default-bsp-post-link
