- Timestamp:
07/16/12 07:22:45 (12 years ago)
- Author:
C Rempel
- Comment:
/* Current / Future Directions */
Legend:
- Unmodified
- Added
- Removed
- Modified
v119
v120
428 | 428 | |
429 | 429 | |
430 | | # Polish the demo, by |
431 | | ## making appropriate calls to main |
432 | | ## possibly renaming main to a more openldap specific function |
433 | | ## adding the appropriate support files (network-demos/ldap/rootfs/etc/...) |
434 | | # Try to get an LDAP connection between RTEMS on Qemu and the build machine |
435 | | # Port SASL to RTEMS and link SASL to the demo |
436 | | # Polish the openldap port by either having all the convienience libraries get installed into a /opt/.../lib/ldap subdirectory and linking from there, or "rolling them into" libslapd.a |
437 | | |
438 | | |
439 | | I explored implementing ldap, ldapsearch, and ldapadd by taking the multiio application from the RTEMS git, and removing as many commands as possible, then adding back in one command at a time. The RTEMS Shell User's guide was very helpful. However, there were "redefiniton issues" (probably because both slapd and the network-demos used init.c). |
440 | | |
441 | | One problem I'm anticipating is the filesystem, but for now, figuring out what calls to main I want, and how to make them is a challenge. |
| 430 | # Polish the demo, by completing the items in the deliverables section. |
| 431 | # Try to get an LDAP connection between RTEMS on Qemu and the build machine. |
| 432 | # Straighten out this site. |
| 433 | Got a very simplistic slapd application to load, now want to port cyrus sasl and verify the functionality of Berkely DB and Open SSL on RTEMS. |
| 434 | |
| 435 | Some problems I'm anticipating is learning how to configure, use, and test OpenLDAP. |
442 | 436 | |
443 | 437 | Hope this helps! |
