47 | | Explore and (possibly port to RTEMS) the additional packages used by OpenLDAP: |
48 | | # Integrate [http://www.rtems.org/wiki/index.php/RTEMS_DBKit Database Support.] One possibility to explore is the Berkely Database [http://www.linuxfromscratch.org/blfs/view/svn/server/db.html BDB.] Although BDB falls under the sleepy cat license, BDB is the default database for OpenLDAP. |
49 | | # Authentication (such as Cyrus SASL) [http://cyrusimap.web.cmu.edu/mediawiki/index.php/Downloads#SASL_Library website][http://git.cyrusimap.org/cyrus-sasl/ git.] Since ldap-bind is being deprecated in favor of ldap-sasl-bind, this extention is needed for a longterm port. |
50 | | # Additional encryption (when configuring openLDAP just type ./configure --help) |
51 | | |
52 | | |
53 | | Explore and (possibly port to RTEMS) the additional packages that use OpenLDAP: |
54 | | # Apache (did this already, but could be ported more efficiently, elegantly, and completely) |
55 | | # Others |
56 | | |
57 | | Explore adding other [http://www.zytrax.com/books/ldap/ opensource LDAP implementations] to RTEMS, the [http://directory.fedoraproject.org/wiki/Main_Page 389 Directory Server] looks like it's written in C (as opposed to Java), so may be a preferred LDAP implementation to port, but additional research is needed to determine such issues as how feasible is it to "embed", and what are the license implications? |
58 | | |
59 | | Add an OpenLDAP test to the RTEMS Networking Demos |
| 47 | #Explore and (possibly port to RTEMS) the additional packages used by OpenLDAP: |
| 48 | ## Integrate [http://www.rtems.org/wiki/index.php/RTEMS_DBKit Database Support.] One possibility to explore is the Berkely Database [http://www.linuxfromscratch.org/blfs/view/svn/server/db.html BDB.] Although BDB falls under the sleepy cat license, BDB is the default database for OpenLDAP. |
| 49 | ## Authentication (such as Cyrus SASL) [http://cyrusimap.web.cmu.edu/mediawiki/index.php/Downloads#SASL_Library website][http://git.cyrusimap.org/cyrus-sasl/ git.] Since ldap-bind is being deprecated in favor of ldap-sasl-bind, this extention is needed for a longterm port. |
| 50 | ## Additional encryption (when configuring openLDAP just type ./configure --help) |
| 51 | # Explore and (possibly port to RTEMS) the additional packages that use OpenLDAP: |
| 52 | ## Apache (did this already, but could be ported more efficiently, elegantly, and completely) |
| 53 | ## Others |
| 54 | # Explore adding other [http://www.zytrax.com/books/ldap/ opensource LDAP implementations] to RTEMS, the [http://directory.fedoraproject.org/wiki/Main_Page 389 Directory Server] looks like it's written in C (as opposed to Java), so may be a preferred LDAP implementation to port, but additional research is needed to determine such issues as how feasible is it to "embed", and what are the license implications? |
| 55 | # Add an OpenLDAP test to the RTEMS Networking Demos |
