| 288 | = Licensing Table = |
| 289 | |
| 290 | The fields in this table are as follows: |
| 291 | |
| 292 | * Project - name of project with hyperlink to it. |
| 293 | * License - software license used. May need to link to license text if dual-licensed or "other". |
| 294 | * Language - what programming language is this written in? |
| 295 | * Active - is the project active? |
| 296 | * OK w/RTEMS Static - Is the license compatible with a statically linked proprietary RTEMS application? |
| 297 | * OK w/RTEMS Technical - Does the code appear to be feasible to run on RTEMS? Does the code make assumptions that would render it unable to run on RTEMS? |
| 298 | * Notes - Anything else |
| 299 | |
| 300 | |
| 301 | {| border="1" style="margin: 1em auto 1em auto;text-align: center;" |
| 302 | |+ |
| 303 | |- |
| 304 | |'''Candidate''' || '''License''' || '''Language''' || '''Active''' || '''OK w/RTEMS Static''' || '''OK w/RTEMS Technical''' ||'''Notes''' |
| 305 | |- |
| 306 | | [http://www.ijg.org/ libjpeg] || Other Open Source License || C || TBD || TBD || None |
| 307 | |- |
| 308 | | [http://www.libtiff.org/ libtiff] || Other Open Source License || C || TBD || TBD || None |
| 309 | |- |
| 310 | | [http://www.libpng.org/pub/png/libpng.html libpng] || Other Open Source License || C (C89) || TBD || TBD || None |
| 311 | |- |
| 312 | | [http://freetype.sourceforge.net/index2.html libfreetype] || GPLv2/FreeType (like BSD) || C || TBD || TBD || None |
| 313 | |- |
| 314 | | [http://www.t1lib.org/ libt1] || GPLv3 || C (C99)|| TBD || TBD || None |
| 315 | |- |
| 316 | | [http://www.microwindows.org/ microwindows] || GPLv2 || C || TBD || TBD || None |
| 317 | |- |
| 318 | | [http://www.libpng.org/pub/png/libpng.html nxlib] || GPLv2 || C || TBD || TBD || None |
| 319 | |- |
| 320 | | [http://www.libpng.org/pub/png/libpng.html svgalib ] || Public License || C || TBD || TBD || None |
| 321 | |- |
| 322 | | [http://www.libpng.org/pub/png/libpng.html fltk] || GPLv3 || C++ || TBD || TBD || None |
| 323 | |- |
| 324 | | [http://www.libpng.org/pub/png/libpng.html GLSL] || GPLv3 || C || TBD || TBD || None |
| 325 | |- |
| 326 | |} |
