- Timestamp:
07/08/12 23:24:32 (12 years ago)
- Author:
Xiaochen Pan
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v30
v31
343 | 343 | |
344 | 344 | Even though all ten frameworks are compared in the above listed aspects, major simulation effort is concentrated on the top five. There is no need to simulate all of them if the test results for any top five framework is satisfiable. |
345 | | = =Host-based Testing==== |
| 345 | == Host-based Testing == |
346 | 346 | |
347 | 347 | |
348 | 348 | For host-based testing framework evaluation, because host based tests are tests that does not rely on rtems APIs, I build and run the tests which are written in each framework. The screenshot are showed in each framework subpage. The screenshot is displayed only to compare the readability of the test output and amount of information contained in each framework. |
| 349 | = =Converted Tests Code Link==== |
| 350 | |
| 351 | |
| 352 | This is the list of converted tests for frameworks CMock, Cmockery, Aceunit and the simulation is done RTEMS based. |
| 353 | http://code.google.com/p/rtems-testing/downloads/list |
