- Timestamp:
07/08/12 09:05:37 (12 years ago)
- Author:
Xiaochen Pan
- Comment:
/* Comparison Note */
Legend:
- Unmodified
- Added
- Removed
- Modified
v21
v22
314 | 314 | # Whether the framework supports mocking functionality |
315 | 315 | # The automation level of tests generation and running |
| 316 | # Whether the framework supports xUnit architecture |
316 | 317 | # The integration difficult of the framework and RTEMS application |
317 | 318 | # The selection of output format of the framework |
320 | 321 | # The popularity of the test framework, the number of downloads each week or in total |
321 | 322 | |
322 | | * The frist few criteria have the higher screening weight. The followed ones are also very important. |
| 323 | * The frist few criteria have the higher screening weight. The followed ones are also very important. The xUnit architecture supports is equivalently important in the sense that frameworks supporting xUnit architecture have edges on better handling relationship between test cases than frameworks that doesn't support. |
323 | 324 | |
324 | 325 | The RTEMS based tests are carried out with BSP=sis and CPU=sparc. For other CPUs and BSPs, further RTEMS based testing of converted current test suites would be simulated in future with the selected framework. |
