- Timestamp:
07/08/12 08:31:41 (12 years ago)
- Author:
Xiaochen Pan
- Comment:
/* Comparison Note */
Legend:
- Unmodified
- Added
- Removed
- Modified
v17
v18
307 | 307 | |
308 | 308 | The list is listed in selection priority order. In other words, CMock is considered to be the top competitive choice for this project. The priority is calculated basing on the following criteria: |
309 | | * Whether the framework supports both RTEMS-based and Host-based Testing |
310 | | * Whether the framework supports mocking functionality |
311 | | * The automation level of tests generation and running |
312 | | * The integration difficult of the framework and RTEMS application |
313 | | * The selection of output format of the framework |
| 309 | # Whether the framework supports both RTEMS-based and Host-based Testing |
| 310 | # Whether the framework supports mocking functionality |
| 311 | # The automation level of tests generation and running |
| 312 | # The integration difficult of the framework and RTEMS application |
| 313 | # The selection of output format of the framework |
| 314 | # The stability of the test framework |
| 315 | # The maintainership of the test framework |
| 316 | # The popularity of the test framework, the number of downloads each week or in total |
| 317 | |
| 318 | * The frist few criteria have the higher screening weight. The followed ones are also very important. |
314 | 319 | |
315 | 320 | The RTEMS based tests are carried out with BSP=sis and CPU=sparc. For other CPUs and BSPs, further RTEMS based testing of converted current test suites would be simulated in future with the selected framework. |
