Changes between Version 5 and Version 6 of Projects/GSoC/TestingReview/CxxTest
Ignore:
Timestamp:
Jul 9, 2012, 12:32:03 AM (7 years ago)
Author:
Xiaochen Pan
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Projects/GSoC/TestingReview/CxxTest
    v5 v6
    44CxxTest is a unit testing framework in C++. It can be used for host-based testing but not for RTEMS based testing, because it does not support C macros preprocessing, which has limited it in RTEMS based testing.
    55
    6 + CxxTest supports  xUnit architecture with test cases, test fixtures and test suites.
     6 * CxxTest supports  xUnit architecture with test cases, test fixtures and test suites.
    77
    8 + It supports the standard XML output.
     8 * It supports the standard XML output.
    99
    10 + It is easy to compile and highly portable because no pre-compiled library is used.
     10 * It is easy to compile and highly portable because no pre-compiled library is used.
    1111
    12 + CxxTest support automatic test runner generation and independent test cases running.
     12 * CxxTest support automatic test runner generation and independent test cases running.
    1313
    14 + It supports mocking functions and mocking objects.
     14 * It supports mocking functions and mocking objects.
    1515
    16 + It supports python scripts.
     16 * It supports python scripts.
