Changes between Version 4 and Version 5 of Projects/GSoC/TestingReview/Cmockery
- Timestamp:
- 07/07/12 18:57:09 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v4 v5 1 1 = TestingReview/Cmockery = 2 2 3 = General Comparison = 3 4 4 5 Cmockery is a lightweight and highly portable unit testing framework with minimum conflicts with standard C library headers. … … 10 11 * Cmockery provides convenient interface to test for memory leaks, buffer underflow and buffer overflow, all of which would cause fatal errors for single processed RTEMS system. 11 12 12 * Cmockery provides a more detailed tests report than CMock by providing the reason for tests failures. 13 * Cmockery provides a more detailed tests report than CMock by providing the reason for tests failures.= RTEMS based Test Results =
