4 | | Check is simple unit testing framework for test-driven development. It forks a separate process for each unit tests. Therefore, it cannot be used in RTEMS-based testing. Test cases, test fixtures, and test suites are well supported by Check with automatic test discovery to promote tests automation. It supports tests debug with a no fork mode. It has multiple output format including XML. It also have a convenient test time out feature to rule out tests take use infinite amount of time. |
| 4 | Check is simple unit testing framework for test-driven development. |
| 5 | |
| 6 | -It forks a separate process for each unit tests. Therefore, it cannot be used in RTEMS-based testing. |
| 7 | |
| 8 | +Test cases, test fixtures, and test suites are well supported by Check with automatic test discovery to promote tests automation. |
| 9 | |
| 10 | +It supports tests debug with a NO-FORK mode. It has multiple output format including XML. |
| 11 | |
| 12 | +It also have a convenient test time out feature to rule out tests take use infinite amount of time. |
