- Timestamp:
10/08/12 05:35:51 (12 years ago)
- Author:
Zhongwei Yao
- Comment:
/* the CONFIGURE of POSIX Key */
Legend:
- Unmodified
- Added
- Removed
- Modified
v13
v14
72 | 72 | |
73 | 73 | there are 2 configuration options for POSIX Key: |
74 | | - CONFIGURE_MAXIMUM_POSIX_KEYS |
75 | | - CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS |
| 74 | - CONFIGURE_MAXIMUM_POSIX_KEYS |
| 75 | - CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS |
76 | 76 | CONFIGURE_MAXIMUM_POSIX_KEYS defines the keys numbers in system. CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS defines the key-thread (or key-task in classic API) pair numbers in system. It's used for more accurate memory control. If CONFIGURE_MAXIMUM_POSIX_KEYS is defined and CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS is not defined, then each thread (and task) would have a key value instance. For example, suppose there are 5 threads in system, and there are 3 threads need key, say they are thread1, thread2, thread3 respectively. Thread1 needs 2 keys, thread2 also needs 2 keys and thread3 only needs 1 key. Then we can define CONFIGURE_MAXIMUM_POSIX_KEYS 2 and define CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS 5. If we doesn't define CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS in above example, then each thread can have its own key data, this is the same as that define CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS 10. So if we are sure about the number of thread would use key in system, we can define CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS to save memory. And CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS <= CONFIGURE_MAXIMUM_POSIX_KEYS is an error. |
