Changes between Version 2 and Version 3 of Projects/GSoC/Atomic_Operations
Ignore:
Timestamp:
Mar 14, 2012, 7:08:40 PM (8 years ago)
Author:
Gedare
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Projects/GSoC/Atomic_Operations
    v2 v3
    3333
    3434A candidate for this project is the ConcurrencyKit (ck). Among other targets, ck works on the 32-bit x86 architecture, so a first step would be to try compiling ck with rtems for pc386 and run a sample application under QEMU. Once a sample application is working, the next step would be to get as much of the ck regression suite to run as possible. Beyond that are many possible directions. Potential students should ask on the mailing list and work with potential mentors to design a project that suits their abilities and goals.
     35= FreeBSD Atomic =
     36
     37The FreeBSD Atomic Operations API defines a set of atomic operations that can then be used to build solutions to concurrency problems. The FreeBSD implementations support a lot of target architectures, so there is more freedom to pick a starting point.
     38
    3539= References =
    3640
