- Timestamp:
09/16/13 23:49:39 (11 years ago)
- Author:
Shubhamsomani
- Comment:
/*GUI DIRECTORY STRUCTURE*/
Legend:
- Unmodified
- Added
- Removed
- Modified
v29
v30
30 | 30 | # Generate a .h file which would be used in an application |
31 | 31 | # Automatically generated by running a command that uses textual substitution/parsing of http://git.rtems.org/rtems/tree/doc/user/conf.t |
32 | | == ===================GUI DIRECTORY STRUCTURE================================ |
| 32 | |
| 33 | GUI DIRECTORY STRUCTURE |
33 | 34 | |
34 | 35 | Controller.py -> Controller of the complete tool. |
| 36 | |
35 | 37 | GUI.py -> File responsible for UI generation. |
| 38 | |
36 | 39 | Generator.py -> File responsible for header file generation. |
| 40 | |
37 | 41 | configuration.ini (present after you save values) -> responsible for storing saved values. |
| 42 | |
38 | 43 | header.h -> The generated header to be used in Applications. |
| 44 | |
39 | 45 | /text/text_parser.py -> The text parser module, which parses the conf.t and fetches neccesary information. |
40 | | The Graphical User Interface is created on the MVC(Model View Controller) framework. |
41 | | In the GUI ,the Model is the conf.t file where definitions of the macros are present. |
42 | | The View is GUI.py file which handles with creating the GUI. |
43 | | The Controller is the Controller.py file. |
| 46 | |
| 47 | The Graphical User Interface is created on the MVC(Model View Controller) framework. In the GUI ,the Model is the conf.t file where definitions of the macros are present. The View is GUI.py file which handles with creating the GUI. The Controller is the Controller.py file. |
44 | 48 | = Goal: = |
45 | 49 | |
