Changes between Version 23 and Version 24 of Projects/GSoC/ApplicationConfigurationGUI
Ignore:
Timestamp:
Apr 9, 2013, 6:27:05 AM (7 years ago)
Author:
C Rempel
Comment:
/* Basic Requirements */
Legend:
Unmodified
Added
Removed
Modified
  • Projects/GSoC/ApplicationConfigurationGUI
    v23 v24
    5757The UI must be portable between all major platforms including
    5858Linux, *BSD, MacOS, and Windows.
     59
     60And any transformation between Users Guide and UI configuration
     61parameter must likely be command line.
     62
     63The UI (4.) could be a command line tools to transform (2.)
     64which is in ASCII into a C file to be compiled. But the UI
     65could also be a TUI (Text User Interface) using ncurses
     66or true GUI using Python.
     67
     68Ultimately the definition of (1.)-(3.) make it possible to
     69implement multiple UIs. But we need a simple portable
     70one first that assumes little. I assume that means a TUI
     71and next a GUI.
     72
     73If you are clever, you can do all of this with some transformation
     74and magic of reading files and generating various dialogs in TUI
     75and GUI form.
    5976==  Code  ==
    6077
