Changes between Version 22 and Version 23 of Projects/GSoC/ApplicationConfigurationGUI
Ignore:
Timestamp:
Apr 9, 2013, 6:25:09 AM (7 years ago)
Author:
C Rempel
Comment:
/* Basic Requirements */
Legend:
Unmodified
Added
Removed
Modified
  • Projects/GSoC/ApplicationConfigurationGUI
    v22 v23
    4444# needs to be shareable in a computer manner between
    4545the users guide and the Configuration Tool.
     46
     47All user dialogs need to be generated based on descriptions
     48of the parameters. There can be no hard-coding of menu
     49options. If we add or delete a parameter, this should just
     50fall out naturally from the descriptions.
     51
     52There needs to be a file format to save user selections.
     53This file format needs to be the same independent of UI.
     54The user should be able to generate a configuration,
     55come back later, load it, edit it, and regenerate C code.
     56
     57The UI must be portable between all major platforms including
     58Linux, *BSD, MacOS, and Windows.
    4659==  Code  ==
    4760
