Changes between Version 3 and Version 4 of Projects/Expat
- Timestamp:
- 06/21/12 21:04:23 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Projects/Expat
v3 v4 38 38 # Template leaf node Makefile 39 39 # 40 The source directory is a relative path to the expat library 40 41 SRCDIR=../../expat/tests 42 43 # C source names, if any, go here -- minus the .c 44 Because BuildTests.sh was not used, each source was listed separately. 41 45 42 # C source names, if any, go here -- minus the .c43 46 C_PIECES= init $(SRCDIR)/minicheck $(SRCDIR)/chardata $(SRCDIR)/runtests 44 47 C_FILES=$(C_PIECES:%=%.c) … … 50 53 CC_FILES=$(CC_PIECES:%=%.cc) 51 54 CC_O_FILES=$(CC_PIECES:%=${ARCH}/%.o) 52 55 56 The header files for the test suite. 53 57 H_FILES= $(SRCDIR)/minicheck.h $(SRCDIR)/chardata.h 54 58 … … 61 65 SRCS=$(C_FILES) $(CC_FILES) $(H_FILES) $(S_FILES) 62 66 OBJS=$(C_O_FILES) $(CC_O_FILES) $(S_O_FILES) 63 67 68 The program to turn into an executable. 64 69 PGMS=${ARCH}/expat.exe 65 70 … … 86 91 LD_PATHS += $(RTEMS_MAKEFILE_PATH)/lib 87 92 LD_LIBS += -lexpat 93 94 I opted not to increase the size for this execuatable, because Expat is a parser, not a server. 88 95 CFLAGS_LD += -Wl,--defsym -Wl,HeapSize=0x200000 # network needs more space 89 96 CFLAGS_DEBUG_V +=
