Changes between Version 5 and Version 6 of Projects/Apache_Runtime
- Timestamp:
- 06/26/12 04:18:09 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v5 v6 4 4 '''Status:''' Exploratory 5 5 6 This project is designed to help a developer interested in porting the Apache Runtime to RTEMS, it is by no means complete. 7 8 The Apache Runtime RTEMS port may make the most sense if it were part of an Apache package; Apache requires alot of software: Apache Runtime (apr), XML parser (Exat), Apache Utilities, Perl Compatible Regular Expression (pcre), and of course, the Apache HTTPD server. 9 6 10 Porting Apache to RTEMS makes the most widely used webserver available to RTEMS system developers. I did the first port of Apache to RTEMS as my master's project, but I wanted a port that would "last the ages", so I am working on a port that can be updated with changes in Apache and RTEMS in less than 2 weeks by an embedded systems developer. 7 11 … … 83 87 make install 84 88 85 It builds, but it's not tested... 89 It builds, but it's not tested...= Next Steps = 86 90 87 91 The next step will be getting the Apache Test Suite up and running in rtems-addon-packages/examples/apr. I'm currently looking at a simpler package to learn more about the rtems-addon-packages/examples I imagine it will be weeks before I get back to this.
