Changes between Version 10 and Version 11 of Projects/Apache_Runtime
- Timestamp:
- 07/12/12 22:38:27 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v10 v11 12 12 Although, my original port was a brute-force approach to the RTEMS source tree, my current attempt utilizes the RTEMS Addon Packages build system. When doing an RTEMS Addon Packges port, there are three files that need to be modified: Makefile.<<lib>>, Makefile, and BuildTests.sh 13 13 14 The shared memory module of the Apache Runtime Library requires memory management (mman) support. To get mman support, you can use the mmap_kit inside of the RTEMS Graphics toolkit 14 The shared memory module of the Apache Runtime Library requires memory management (mman) support. To get mman support, you can use the mmap_kit inside of the RTEMS Graphics toolkit. 15 15 16 16 ~$ git clone git://git.rtems.org/rtems-graphics-toolkit.git … … 18 18 ~$ make && make install 19 19 20 Now you that have very basic memory management (mman) support, you can install the Apache Runtime Library. 20 Another approach that I will explore in the near future is to use the [ http://git.rtems.org/chrisj/rtl.git/ RTEMS Runtime Linker library.] 21 22 ~$ git clone git://http://git.rtems.org/chrisj/rtl.git/ 23 24 25 Once you have basic memory management (mman) support, you can install the Apache Runtime Library. 21 26 = Makefile.apr = 22 27
