Changes between Version 45 and Version 46 of Packages/SQLite
Ignore:
Timestamp:
Jan 27, 2015, 12:20:10 AM (5 years ago)
Author:
Wendell P Silva
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Packages/SQLite
    v45 v46
    9898Using the configuration above with RTEMS 4.10.2, SQLite 3.8.8.1, pc386 BSP, reveals that "in-memory" databases works amazingly well. However, you may experience "I/O disk failure" with persistent database on msdos partitions. Probably, a new RTEMS-specific VFS (Virtual File System, in SQLite jargon) must to be implemented using low-level open/read/write/close directives.
    9999
     100The increase of the image size (compiled with -O2 -g) is quite big:
     101 .TEXT: +482KiB
     102
     103 .DATA: +3KiB
     104
     105 .BSS: +1KiB
     106
     107
    100108Further investigation in progress.
    101109
