Changes between Version 18 and Version 19 of Packages/LWIP
Ignore:
Timestamp:
Jan 3, 2020, 7:45:23 PM (16 months ago)
Author:
Gedare Bloom
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Packages/LWIP
    v18 v19
    1616https://git.rtems.org/rtems-source-builder/tree/source-builder/config/lwip-1.cfg
    1717
    18 Update the RTEMS port of LWIP.  Provide reproducible test cases so we can be sure it stays in working condition. See discussion on [wiki:https://www.rtems.org/pr1712 PR1712]
     18Update the RTEMS port of LWIP.  Provide reproducible test cases so we can be sure it stays in working condition. See discussion on #1712.
    1919
    2020A goal of this effort is to be able to use the standard TCP/IP NIC drivers already in RTEMS.  If this is feasible, then a user could switch between the full-featured BSD TCP/IP stack in RTEMS or the LWIP stack to save memory at the expense of reduced functionality.
