- Timestamp:
11/28/18 09:34:45 (6 years ago)
- Author:
Pritish Jain
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v10
v11
79 | 79 | = OpenMP Validation = |
80 | 80 | |
81 | | Originally the [http://web.cs.uh.edu/~openuh/download/ OpenMP 3.1 Validation Suite] was selected to validate the OpenMP support. Due to some problems with this,the test suite results are currently not available. Tests that failed on RTEMS failed also on Linux. There were two related bug reports to GCC [https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65385 Bug 65385] and [https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65386 Bug 65386]. The quality of the test suite itself turned out to be quite bad. |
| 81 | Originally the [http://web.cs.uh.edu/~openuh/download/ OpenMP 3.1 Validation Suite] was selected to validate the OpenMP support. Due to some problems with this test suite, results are currently not available. Tests that failed on RTEMS failed also on Linux. There were two related bug reports to GCC [https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65385 Bug 65385] and [https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65386 Bug 65386]. The quality of the test suite itself turned out to be quite bad. |
