Changes between Version 10 and Version 11 of NewTicket
Ignore:
Timestamp:
Aug 14, 2019, 5:34:00 AM (23 months ago)
Author:
Sebastian Huber
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • NewTicket
    v10 v11
    1 = Please Read Before Creating a Ticket =
     1Thank you for your interest in submitting a bug report.  Before submitting a ticket, please try the following four things:
    22
    3 Thank you for your interest in submitting a bug report.  Before you get started, please read through this short document to better help us address the issue you will be reporting.
    4
    5 [[Notice(Before submitting a ticket, please try the following three things:)]]
    6
    7  1. View the [https://devel.rtems.org/query View Tickets] Page
     3 1. View the [https://devel.rtems.org/query View Tickets] page.
    84 1. Search for your problem.
    95{{{
    1511</form>
    1612}}}
    17   If this search isn't advanced enough for you, then try the [/query Advanced Search].
     13  If this search is not advanced enough for you, then try the [/query Advanced Search].
    1814 1. Review the [https://docs.rtems.org/branches/master/user/support/bugs.html RTEMS Bug Reporting] page.
     15 1. If you have read the [https://docs.rtems.org/branches/master/user/support/bugs.html RTEMS Bug Reporting] page, you can [/newticket submit a ticket].
    1916
    20 ----
    21 = Required Information =
    22 It's not mandatory to fill in all the information, but at the very least, these fields are required:
    23
    24  1. '''Summary'''
    25   * Keep this short and concise as to what your problem is.
    26  1. '''Description'''
    27   * Include as many details of your problem as possible.
    28   * Platform info (if applicable)
    29    * Operating System name
    30    * Version
    31    * Any other relevant platform information.
    32  1. '''Type'''
    33   * '''defect''' - A bug in the program or documentation.
    34   * '''enhancement''' - A feature request in the software, or addition to the documentation.
    35  1. '''Version'''
    36   * Set it to the version you're using. If it is the [wiki:Developer/Git Git] version (not an official release), then set it to ''master''.
    37  1. '''Test Cases'''
    38   * Where possible, please attach or provide an in-line example that reproduces this problem.  Try to make it the least possible amount of code to trigger the issue.
    39
    40 == Attaching Files ==
    41 If you have any external files, such as screenshots or examples, please ''attach'' these as files to the ticket. __Do not use external hosting__ because if you do use external hosting, then our historical record is broken when those files are no longer available.
    42
    43 ----
    44 = Fields =
    45 Some fields should only be set by the developers, as it's not always clear what they should be set to. Feel free to make your own choices.
    46
    47
    48 ----
    49 = Submitting a Ticket =
    50 In order to submit a ticket, you must first [/register register].
    51
    52 If you've read this page, you can [/newticket submit a ticket].
    53
