Changes between Version 62 and Version 63 of GSoC
- Timestamp:
- 03/12/22 23:50:18 (2 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
GSoC
v62 v63 17 17 * Read through all the material on this page. 18 18 19 * Talk to us on Discord or the RTEMS mailing lists.19 * Talk to us on [wiki:Developer/Discord] or the [wiki:RTEMSMailingLists RTEMS mailing lists]. The best place to get your questions answered is the #gsoc channel in the Discord! The devel mailing list is also good but sometimes takes longer to get a reply. 20 20 21 * If accepted as an organization, contributors applying to the RTEMS Project will need to fill out an application at [https://summerofcode.withgoogle.com Google Summer of Code].21 * Contributors applying to the RTEMS Project will need to fill out an application at [https://summerofcode.withgoogle.com Google Summer of Code]. 22 22 23 23 * You will also need to fill in and later update the information found on the [wiki:GSoC/2022 RTEMS GSoC] tracking page. 24 24 25 * We also require you build RTEMS, create an application, run it and post the result to the RTEMS mailing list. The [wiki:GSoC/GettingStarted GSoC Getting Started] page has some more information. 25 * We also require you build RTEMS, create an application, run it and post the result to the RTEMS mailing list. The [wiki:GSoC/GettingStarted GSoC Getting Started] page has some more information. This is a requirement for participation, and should also help you to get going. 26 26 27 * Pick a project from the list at [wiki:Developer/OpenProjects Open Projects]. This is by no means an all-inclusive list and we are open to suggestions. Submissions of ports to new architectures, new BSPs, new device drivers, and test improvements are always welcomed.27 * Pick a project from the list at [wiki:Developer/OpenProjects Open Projects]. This is by no means an all-inclusive list and we are open to suggestions. Submissions of ports to new architectures, new BSPs, new device drivers, and test improvements are always welcomed. Mentors can be reached by Discord or the devel mailing list. 28 28 29 29 * Code your heart out and have a great summer!
