- Timestamp:
06/14/23 13:36:10 (11 months ago)
- Author:
Utkarsh Verma
- Comment:
Add status updates for Utkarsh
Legend:
- Unmodified
- Added
- Removed
- Modified
v46
v47
103 | 103 | * Blocker: Tried to build the rtems-test but failed to do so |
104 | 104 | * Next week's work: Build a simple application, Start the work on GPIO driver |
| 105 | |
| 106 | == Utkarsh Verma == |
| 107 | * **June 7**: Coding Period Week !#2 |
| 108 | * Last week's work: Read about the existing GPIO driver in the arm/raspberrypi BSP and explored the RTEMS codebase. |
| 109 | * Blocker: The codebase is a bit big and there is vagueness in the approach to take for the driver implementation. |
| 110 | * Next week: Implementing the driver and looking into FDTs |
| 111 | * **June 14**: Coding Period Week !#3 |
| 112 | * Last week's work: |
| 113 | * Found a BSP lookup bug in rtems_waf and raised a ticket (#4917) proposing a fix. |
| 114 | * Fixed the RTEMS docs build system for newer versions of Sphinx. |
| 115 | * Tested and validated a basic hardware setup to build upon. Created a new [https://github.com/UtkarshVerma/rtems-on-rpi4b repository] to contain examples for showcasing peripheral usage as the BSP support improves. |
| 116 | * Discussed possible approaches to implement the GPIO driver with mentors. |
| 117 | * Blocker: Getting used to the RTEMS codebase and understanding the principles before implementing the driver. |
| 118 | * Next week: Start with the GPIO driver implementation around the GPIO2 interface. |
