| 1 | = Google Summer of Code 2023 = |
| 2 | |
| 3 | [[TOC(GSoC/2023, depth=2)]] |
| 4 | |
| 5 | This page is for the contributors who make proposals as well as those who work on projects for RTEMS as part of GSoC 2023. |
| 6 | |
| 7 | |
| 8 | = Contributors' Proposals = |
| 9 | |
| 10 | Start filling in this table for yourself as soon as possible and update as needed. |
| 11 | |
| 12 | || '''Contributor Name''' || '''Completed Hello''' || '''Discord Handle''' || '''Proposal Title''' || '''Google Docs URL''' || '''Final Submitted''' |
| 13 | |
| 14 | |
| 15 | |
| 16 | |
| 17 | |
| 18 | The columns are to be filled in as follows: |
| 19 | * The ''Contributor'' column is for your name. |
| 20 | * The ''Completed Hello'' column lets us all know whether or not you completed the mandatory Hello World project. Email your proof to Gedare, Joel, and Chris Johns. |
| 21 | * The ''nick on Discord'' column is your handle on Discord. RTEMS folks hang out there with best-effort service. |
| 22 | * The ''Proposal Title'' should be self-explanatory. |
| 23 | * The ''Google Docs URL'' is your proposal in Google Docs that can be reviewed and commented on by mentors. The [https://docs.google.com/document/d/1F5XCodvX8AYNqWX5ssu7dfjkmFT__83uf8ABKbB_Pkg/edit?usp=sharing proposal template] should be '''copied''' and used as a baseline. This can be shared with mentors for review. Mentors can insert comments for you. You can use this as your Draft Proposal in the [https://summerofcode.withgoogle.com GSoC site]. |
| 24 | * The ''Final Submitted'' should be set to Yes when you have submitted your Final PDF proposal on the official [https://summerofcode.withgoogle.com GSoC site]. If you do not submit the final proposal via the Google site, you cannot be considered! |
| 25 | |
| 26 | = Contributors' Summer of Code Tracking Table = |
| 27 | |
| 28 | Contributors whose GSoC project is accepted by RTEMS shall fill in a slot with their information in the following table, which helps to centralize [wiki:Developer/GSoC/ProjectManagement SoC Project Management]. |
| 29 | ||'''Contributor Name'''|| '''Handle''' || '''Project Link''' || '''Repository Link on Github''' || '''Blog''' || '''Calendar''' |
| 30 | ||NAME || nick on Discord || [https://devel.rtems.org/wiki/GSoC/2022 Project Wiki] || [https://github.com/rtems/rtems Project's Github repo] || [https://www.rtems.org Blog] || [https://calender.google.com Project Schedule] |
| 31 | |
| 32 | |
| 33 | The columns are to be filled in as follows: |
| 34 | * The ''Contributor Name'' column is for your name. |
| 35 | * The ''Handle'' column is your nickname on Discord. |
| 36 | * The ''Project Link'' is a link to the Wiki page for your project. |
| 37 | * The ''Repository Link on Github'' is a link to the Github repository for your project. It should be a specific repository, not just your github account! |
| 38 | * The ''Blog'' is a link to your blog with entries about your project. It should be updated regularly during the summer. |
| 39 | * The '''Calendar''' is a link to your Google Calendar with milestones and deliverables identified. |
| 40 | |
| 41 | = Contributor Status Updates = |
| 42 | Each contributor has a section below for putting in notes from the weekly Discord meetings. |
| 43 | |
| 44 | == Gedare == |
| 45 | * Jan 23: Tracking status page created. Org Application Submitted. |
| 46 | |
| 47 | |
| 48 | |
| 49 | |
